Onan Cranking Current.
Matt Colie
11,101
807
113
South East Michigan near DTW
About Onan cranking current.
Quick answer:
152 Amp peak
91 Amp RMS
There was recently some discussion about this and I happened to have:
This all about a BF (4.0) Onan. I don't know how it would relate to and NH (6.0).
A - An Onan start switch close to the Onan's battery (its a 23).
B - My instrument case in the coach for several reasons.
C - Time to do this experiment.
So, I have an 87 and Bell probe (they are both old, but still good) and I put the probe on the power to the Onan and set the Fluke up to capture. It
was cold enough that I hoped the Onan. I got two good 3~5 second cranks before it started.
This was in about 50° weather and with a nice running BF that has had 10-30 Mobil 1 in it as long as I have owned it.
The Onan's battery was new two years ago.
So, if you care, you have that for a data point.
Hi Matt,
The peak value is a good reference point but the RMS value doesn’t hold much relevance on a DC circuit since RMS is really only meaningful on periodic signals such as those found in AC circuits.
Do you know the condition of your starter - as in how long ago it might have been rebuilt? The misbehaving Onan starters that we’ve worked on at the Miller compound almost universally have had a worn out nose bearing that results in substantial current draw but minimal cranking enthusiasm. Some owners were attributing the starter’s lethargy to bad batteries, wiring problems, solenoid issues etc but all it turned out to be is a bronze bushing that costs less than a dollar and takes only a few minutes to replace once the starter is off the machine. I would never have guessed that a sleeve bearing that was worn only a slight amount could result in this situation but if one thinks about the radial load on the starter’s armature during starting then I guess it makes sense.
Thanks for posting your measurements!
--Jim Miller
1977 Eleganza
1977 Royale
Hamilton, OH
> Quick answer:
> 152 Amp peak
> 91 Amp RMS
> Matt
A little off topic, but just for the record, Jim Miller saved my Oman nearly 3 years ago when I was new to this group. Many thanks to Jim and others
who have helped with numerous items. Jim = Onan Rock Star!
1978 GMC Royal
Eastern Pennslyvania
1968 Chevrolet C20 396 Camper Special
1969 Chevrolet C20 Camper Special
1985 Buick Electra Park Avenue
1992 Camaro 25th Anniversary Heretage Edition Black
They can be made into truely finger tip starting units, by simply catching up with the years of neglected maintenance compounded by age and
environment. Mine was an instant start every time on our last 2 week trip in mostly cold weather. All stock no fuel pump pre run button.
John Lebetski
Woodstock, IL
Source America First
