Andy M PA
To replace the Onan OEM Bridge Rectifier is a 10 minute job. Takes a
little longer to install an after market High Voltage Rated unit since
the pin out arrangement is different, but it is worth the effort for
piece of mind.
Slide the Onan out as far as it will go & go to the right rear (behind
the control Board) & remove the two black plastic screens around the
Generator Housing. Between the two screens is a 1/4" bolt head on the
generators housing. Remove this bolt & the BR will drop down out of the
housing. Carefully note the pin out orientation before removing the BR.
The BR will insert 4 different ways.....only one way works....so don't
screw up & get in a hurry.
Happy Onaning
Duane of Orange CA
piece of mind.
Happy Onaning
Duane of Orange CA
