Onan 6k power drawer 2024
Don Jaksa
421
209
43
I saw this for offer and decided I had to get it
I am glad to get it even if I just take it apart and see what is inside
but first I want to see if I can get it running
I have a 4k in my 73 Canyon Lands so this is the SECOND Onan power-drawer I have ever seen in person
No exhaust or muffler
Main circuit breaker replaced
Came with the flywheel exposed
I'm sure the control board works perfectly
Starter looks ok from 3 feet
Parts bits and pieces
No typical scorch mark on the upper left of the faceplate
Alright! A free Ragusa diverter
It looks like the previous owner was in the middle of installing the ignitor but never finished
The plate has not been drilled to mount the device
The points are still hooked up
The points are the upgraded top access with hex-nut adjustable gap. Maybe the ignitor was next on the list
Box-o-parts. There is a second air inlet cast with rubber hose
And a hilarious pseudo-exhaust
brackets mounts and nuts
Covers off the wiring side
Someone changed the spark plug wires
Rectifier seems intact and still wired for charging
This pile of junk is a treasure trove
Reactions: Christo
The first time I ever got the opportunity to compare the two models
My recently brought-back-to-life-restoration of the original 4k power-drawer
I pride myself that it slides in and out with one hand
New rubber mounts are essential.
I am missing the main pan enclosure, specific to the 6k
Now I really wish that those ONAN muffler dreams had come true
Reactions: Russell and pvfjr
After examining exactly what I have
I am missing:
the pan #4
#7 bracket
#20 pipe and #22 clamp
but I have two #1 hanger frames
The Onan power drawers have a nice eye-bolt and using my engine hoist I was able to maneuver the unit onto a roll around platform and then sort-of-secure it so it is not resting on anything it should not
Using that second piece of iron I am able to prop it up pretty solid
This is the business end of the generator,
The black wire POS routes around to the front and attaches to the 50 amp circuit breaker. the other side of the circuit breaker routes back thru the cable management system and, along with the double ground wire, connects to the junction box for distribution to the coach
Missing exhaust
First a couple of squirts of oil in the cylinders and a compression test
I have looked at the wiring and it appears intact
I'm going to get a couple of battery cables, a battery and see if it turns over
That oil filter looks suspiciously short
I made my own controller board with two relays and a oil pressure switch from a GMC for operating the automatic choke. works great
The "electronic components" on the control board are simply a time delay circuit to allow the oil pressure to build when starting the engine before the "low oil pressure shut down" is enabled. The two relays control the engine starter and ignition. Pretty simple circuit.
The original onan control board is way to complicated and expensive to replace for it actually does.
Expensive parts is what invites companies like Dinosaur and Flight Systems to make replacements. Over on FB, a fellow recently purchased a $2 bridge rectifier from Onan (Cummins) for $70.00 even after people posted generic replacements for a couple bucks. But the guy wanted OEM and paid for it.... but when he got it there was instructions to bend the pins to fit!!
Dinosaur and Flight's replacement boards are expensive enough, but very low sales quantities means they likely keep a production run in stock for a few years.
  • Haha
Flight Systems makes great stuff, I'd love to know the backstory. I have a feeling the owner was an avid RVer and saw a need for an improved Onan control board.
Here is the control board
I connected a couple of battery cables to the new 6k generator
Quality ground
Connection to the starter
Jumping 5 to 9 started the fuel pump, so I disconnected that for now
I decided to try the starter...it did nothing when engaged, so I got some spray lube and a hammer to gently tap on the starter housing
Works like a charm
Starter engages now and I saw the e-choke solenoid engage...well maybe not
I only wanted to see that the starter CAN engage
I did not rotate the engine, but it clearly could
Next I'll see if the points spark and then its on to fuel and an exhaust
Spark and compression
I pulled the finger-tight sparkalators which seemed okay and not fouled
Squirted some Marvel mystery in the chambers and blew some light air to get it all slicked up
Checked the gap with this handy feeler gauge
Hooked up my compression tester that I hadn't used in 40 years
The best reading per side was just about 30 PSI with a hand crank
Seemed even per cylinder
Looking at the points:
Upgraded with adjustable dwell, they do toggle when cranking
Where's that sand paper?
30 psi is way too low.
Did you hold the carb wide open while cranking?
Did you keep a charger on the battery so it would crank pretty hard and consistent?
Naw, I did not crank it over, I just turned it over by hand
I was glad it read any PSI
Honestly I could have gotten the same results if I had just held my finger over the plug hole, the gauge thing was all playing around with a gizmo
I want to check the oil and the fuel filter and hook up a remote gas tank/can next to my fire extinguisher before I attempt to start it
That 120vac wire sticking out the back has to be secured as well
oh yeah, no muffler yet, I'm going need one of those (I have a line on a 155-1247) but I will need the pipe and flange
then roll it out into the driveway...could be a while
If it has been a while since that Onan has run...like more than a couple of years...it would be a good idea, while the plugs are out....to let the starter turn that engine over for at least 30sec to let the oil pump get oil to all of the bearing surfaces. JWID
Reactions: Don Jaksa
You might consider popping off the seal on the rear bearing and putting in some fresh grease. Easy to get at with the genset out of it's compartment. Bob Stone's suggestion
Pulled the cover to grease the rear bearing, what the heck, it doesn't cost anything
I guess I'll just squeeze grease in there anyway I can
I used all purpose grease and a big syringe to inject grease into the bearing, then rotate, inject, rotate, then press grease into the bearing with a gloved finger. Once the grease was all smooshed in and the bearing slickered up, I pressed the seal back in place and wiped off the excess
Reactions: pvfjr and Wally
A little lube spray and a 5/8" box wrench removes the bottom cover to reveal a brand new unused fuel filter/screen
The rubber seal is rock hard, so I am going to try soaking it in brake fluid to restore the volatiles
until the replacement gets here
My Onan 4k had an original ceramic fuel filter that I changed
After 2 days soaking in brake fluid and over-night drying, the previously rock-hard rubber fuel pump seal is restored and flexible again
