> What is the correct ID and OD for the Onan drawer to fuel pump. Should I go with Tygon or Stens True Blue? Are they the same? I think I am
> getting the " refigerator door light" syndrome where it runs fine pulled out and pinches off put away. Age is unknown so want to eliminate the risk
> by installing fresh.
Did you ever resolve the issue to your satisfaction? I believe I am having this same issue with my onan. Put the electronic ignition on the Onan (the
first time I pulled the drawer out) Pushed the drawer back in after wrapping up the install and it would not start. I pulled the drawer out and tried
to start from the Onan itself it started right up and ran perfectly. So I stopped it and pushed it back in. We packed up the coach to take the
grandkids to the beach and being a bit warm tried to start the gen and once again crank but no run.
Has anyone found hose that will reliably not kink?
Tom Lins
Elkton, FL
77 GM Rear Twin, Dry Bath, 455
Tom Lins
Elkton, FL
