oil/trans coolers
chris izzig
136
on page 91 of the summit catalogue they advertise a combo oil trans cooler with a 500 or 900 cfm fan for $150-170. will this work on the gmc and can i tee it into one of the existing lines?
thanx chris 75gb
Join 18 million Eudora users by signing up for a free Eudora Web-Mail account at http://www.eudoramail.com
The oil cooler for the engine is more that enough for the engine oil.
As for the tranny cooler I have added an 22 to 24,000 GVW cooler similar
to the one on the next page for $49.99. Have it mounted in front of the
radiator and also have a air damn spoiler to increase air flow thru the
unit. Your oil cooler line are 1/2" in size and this cooler is only
3/8" connections. I would be careful on restricting the oil flow.
Tranny cooler lines are 5/16". If you decide to added so sort of cooler
be sure to not to use the nylon ties that go thru the radiator. They
will cost you your radiator as they will destroy the fins and rub holes
in the core.
J.R. Wright
GMC GreatLakers
Michigan
> thanx chris 75gb
