I am thinking about removing the oil lines going to the radiator and
replacing them with a stand alone engine oil cooler such as the summit six
pass oil cooler PRM-12315(4"H X 101/2"W X 18"L for $149.95. It comes with a
900 CFM fan and will reduce the temperature up to 95 degrees F. Am thinking
about the same thing for the tranny. Think it would solve several problems,
fire danger if the lines burst, and better cooling for the tranny and engine.
Has anyone gone this route yet and if so what is your experience?
>Rick, one other thing to check for sure. Check the oil cooler lines that run
>from the oil filter to the radiator. If they are hard and not flexible,
>change them out before you start. You can take them off fairly easy and find
>a place that makes hydraulic lines for heavy equipment, or order from one of
>the suppliers. If it is near a fairly large town or city, you shouldn't have a
>problem finding a source for the hoses.
>Justin
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
>Justin
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
