Now it runs
Bob Dunahugh
2,784
4
3
My NEW relay wouldn't run the aux tank pump. So I ran a jumper wire to the aux pump. BINGO. Back running again. The NEW Airtex number E8094 worked great last night for 3 blocks. ( And I did have a filter between the pump, and tank.)So what's the track record on this pump? Two sheets to the wind Bob.
I ordered two more pumps today..One as a backup. Then a second backup for the first backup. This is NUTS. My tanks are spotless. The filters mounted before the pump have absolutely nothing in them in the way of junk. Maybe I should get a hand crank pump that Linda can use. Or one with a treadmill that the dog can power. May need more Scotch. Bob Dunahugh
Sent: Thursday, September 7, 2017 1:30 PM
Subject: Now it runs
Golly, Bob, have you yet tried any of the recommended Carter P4070 pumps? I
keep seeing pump brands go by--pumps that were whatever cheapie brand that
was available in an emergency--but not the Carter. I bought one recently in
preparation for a dual-pump setup, and it's still made in USA. The old one
still works fine after 13 years.
Also, maybe don't clamp them to the exhaust pipe. (That was a joke.)
Rick "make some luck" Denney
> From: Bob Dunahugh
> To: gmclist
> wind Bob.
Rick Denney
73 x-Glacier 230 "Jaws"
Richard. On my last trip. I took a Carter 4070 with me. And that's what got me home. I just installed an EFI system now. Thus needed a higher pressure pump. Then one of the higher pressure pumps failed. Bob Dunahugh
