Hi Scott
Your computer is finding the speaker phone feature of your modem when it
boots up. Evidently a driver for this feature hasn't been installed or has
been corrupted and since it keeps happening at each boot-up, it isn't
finding a satisfactory driver.
If you have the disks that came with your computer or modem, put them in
the drive and click 'Next'. Direct it to the disk drive and it should find
it or you should be able to select the driver from there.
Or, go to your Control Panel and select 'Add New Hardware'. Tell it you
want to install a 'sound' controller and push the 'Have Disk'
button. Direct it to the disk drive and you should be able to select the
driver from there.
If this doesn't work and you don't need this feature anyhow, you can
disable it by going to the 'control panel' and selecting the 'system'
icon. Then select the 'Device Manager' tab and navigate down to the
'sound' entry. If 'Wave device for Voice Modem' is there, double click on
it to see it's property sheet. At the bottom of the sheet will be a box to
check if you want to disable this feature. Hopefully that will make it
quit looking for it every time it boots up.
I think the little random appearing error box will quit showing up if you
get the above problem taken care of. If it doesn't work, holler and we'll
try something else.
hth
bdub
>GMC GEEKS HELP!
>I have had various thing go wrong with my computer and have been able to
>"fix" them. What I did to fix them was probably by mistake/luck! My most
>pressing problems are displayed at:
>http://albums.photopoint.com/j/AlbumIndex?u=202164&a=5239851 along with some
>text and pictures of what happens to my screen. Please take a look and see
>if you might have been there done that.
>The text for the pictures are:
>Right after booting up before Windows is on the screen, I get this 3 times,
>alternating with the picture to the right.
>This picture displays after the picture on the left momentarily. HOW DO I GET
>RID OF THESE SCREENS?
>This little bugger comes an goes whenever it feels like it. Sometimes I have
>to click it once and sometimes 3 or 4 times to get it to go away. I am
>starting to feel like I'm one of Pavlov's dogs. WHAT IS IT AND HOW DO I GET
>RID OF IT?
> _____NEXT QUESTION_____ The next problem I have has to deal with fonts. It
>seems all of a sudden when I download a website(others) and my own websites,
>the size of the fonts is larger. How do I fix?
>Thanks Guys and Gals,
>Scott NEHODA'S
>BACK YARD
driver from there.
try something else.
hth
bdub
>GMC GEEKS HELP!
>RID OF IT?
>Scott NEHODA'S
>BACK YARD
