> Any suggestions on debugging my dead dash lights. The dash lights have
> never worked for me and the 4A fuse for the dash lights blows as soon as the
> lights are turned on. That is as far as I have take it? Any advice would be
> great. Thanks.
Not much help - just start with the wiring diagram in the manual and
work backwards. Did that with mine and found a bad dimmer. Your
problem sounds more serious tho'. There's a short somewhere. You might
start by looking for and disconnecting any PO added "custom" wiring.
IIRC, there's a gray wire behind the dash that goes to ground when the
switch is off. It's sometimes mistaken for a ground wire, and if wired
into a grounded chasis radio, would have the effect you mentioned(blown
fuse).
> BTW, I fetched our GMC from storage this weekend. The old battery would not
> crank her over even when jumping it with my mini-van? What does it take to
> get these beasts to crank?
I'd suspect a bad starter ground or possibly bad battery cables. My
WalMart battery works just fine.
Good luck,
Patrick
Patrick Flowers
Mailto
atrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
> great. Thanks.
fuse).
Good luck,
Patrick
Patrick Flowers
Mailto
