No cold water in Kitchen
mike ballard
19
Getting the water system back in shape after a winter without winterization and a leaking hot water heater. After replacing a cracked fitting behind
the electrical cabinet and getting the hot water heater replaced, I was testing all the connections I could get to, and verifying operation. With no
leaks observed I switched on the water heater and gave it a few minutes to warm up. Testing for hot water in the bathroom everything seemed fine.
Testing in the kitchen, I had warm water. All good, I thought, but rotating the kitchen faucet valve only produced warm water, no cold. I thought
this might just be the faucet valve not working correctly, but checking the water lines under the sink, I found both of them warm. Seems warm water
was flowing through both lines. This was with shoreline water connected. Any idea why this might be happening?
Mike & Apryl Ballard
Fair Play, Missouri
1975 Glenbrook
Hose coming into coach in the sun warming the incoming water? Cross connection in water lines?
Hal
1977 Royale 101348,
1975 Eleganza II, 101230,
Rio Rancho, NM
