Nichrome wire bypass
6cuda6
945
163
43
59
Ontario, Canada
Ok ok...i know there are tons of posts and pics etc but heres the question:
Should one re-wire the whole circuit as JB suggests? I see pics of how Kelvin did it by splicing in and clipping one end of the nichrome?
To much info sometimes is just as bad as not enough......the mechanic in me says re-wire the whole circuit....the practical side says a bypass can be
just as good.
I only want to do this once so i want opinions from those who have personally done this.
Rich Mondor,
Brockville, ON
77 Hughes 2600
You could bypass it but do not use a 100 ohm resistor as Jim B. states. He misread the wiring diagram years ago. The diagram shows a 10.0 ohm
resistance wire and he read it as 100 ohm (missing the decimal point).
Gene Fisher came up with a simpler solution by inserting a diode in series with the start lead of alternator. He makes a "plug and Play" device he
calls an APC (Alternator Protection Cable). It is $20 or $25 and I think Jim K has them. It is a 5 or 10 minute no tool install.
Diode will not allow current to flow in the nichrome wire if the voltage on Pin 1 (excitation) goes above the chassis battery voltage. It does not
prevent the flow when the key is turned to ignition but the engine is not started... or if the alternator fails (broken belt, no power out etc) and
you continue to drive (powering off house battery or onan)... in that case the GEN light will be ON and current will continue to flow in the nichrome
wire and dissipate heat.
I'm thinking to replace the nichrome wire with a single filament 12V lamp that is rated at about 1 Amp current (such as a single filament tail lamp).
The lamp will be the correct resistance and will dissipate the heat generated. If something happened to the alternator to cause excessive voltage at
Pin 1, the bulb will get very bright and will burn out cutting the current flow.
Anytime the GEN light is ON, the nichrome wire has current flowing in it and is dissipating heat (about 10-12 watts).
Just a thought.
Bruce Hislop
ON Canada
Since Gene Fisher's APC came into use, I haven't heard of a single Nichrome
wire incident (with the APC installed). So, I'd feel comfortable using it
only. However, Bruce's point about heating is valid -- I replaced the Wire
with a fixed 10Ohm/25W resistor, before the APC appeared, with it mounted
in the HVAC airflow.
That’s exactly what I did, when KenH and I were making do with what could
be bought off-the-shelf in Bean Station. It was a temporary measure. It’s
still there. :)
Rick “~15-watt lamp = ~1 amp = ~10 ohms” Denney
On Thu, Nov 14, 2019 at 5:19 AM Bruce Hislop via Gmclist <
> voltage at
> flow.
> Just a thought.
> Bruce Hislop
> ON Canada
'73 X-Glacier 230 "Jaws"
Northern Virginia
