It seems that most people have a hard time picking tires. I do not
profess to be an expert but a little research goes a long ways. If the
tires you have are suspect, then go to your tire shop and have them
evaluated. Most tire shops are honest, at least I believe that, and will
give you a good evaluation. I do not understand the big hoopla about
Goodyear 159's or whatever they are. When I was picking up my 26' in New
Mexico, the tires that were on it were seriously deteriorated. Not
wanting to part with a whole lot of money I ventured to the recommended
shop to purchase some used ones (7 of them). Picked up a fairly
reasonable set for just under $160.00 U.S., drove the 2000 miles back
home and didn't have any problems. When I got home I found that the
alignment in the rear was a little off, because one of the forward rears
showed some wear on only one side of the tread. Weather the tires are
"E" rated or "D" the most important thing is that its load carrying
ability is stamped on the tire itself. The easiest solution seems to be
to weigh your coach and add a reasonable amount for cargo and pick your
tires. Remember to weigh each axle separately. Also it is a good idea to
buy a matched set as this will ensure the coach will track properly. As
far as the age thing goes, as it applies to tires, it is a simple thing
to get checked. If it ain't broke and you don't want to upgrade then
don't fix it. My .05 cents(canadian) worth. Darren
> -- [ From: Eugene Fisher * EMC.Ver #2.5.3 ] --
> I love my Goodyear tires
> They are only 6 years old
> I am at serious risk
> So I am told
> The tread is thick and healthy
> What a waste
> You can see they look real good
> Am I acting in haste?
> Can I afford a blow-out
> That may tear out the GMC's side
> A blow-out at 60
> Might be suicide
> Please Mr. Tire Man
> Please take my money
> You have saved me worry and anguish
> You have saved me aplenty
> Gene
> Gene 76Palm Beach /Or/CA
> GMC Technical Information
> http://www.california.com/~eagle/
> So I am told
> What a waste
> A blow-out at 60
> Might be suicide
> Please Mr. Tire Man
> Gene
