Arch,
This sounds like a great idea. As for the water
shuting down the engine....I hope mine will run
through a rain storm...And Im sure I wont have to
worry about a gallon of water spraying on the engine.
Im also sure if Im pulling a hill My engine would
be plenty hot enough to dryout any water that
gets there. Heck, A little water in the carb would
help eliminate a pre-detonation problem in the
cylinders if ya got one.
Rob Teed 74 Painted Desert
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of Thomas G.
> Warner
> Sent: Saturday, December 05, 1998 1:06 PM
> To: gmcmotorhome
> Subject: Re: GMC: New Subject
> Excellent way to coold down the engine Arch. Let me make sure that I get
> this right, I might consider it. I have filled in some of the
> steps you may
> have missed, between when you hit the water switch and spray the radiator
> and the engine cooling off. The fan catches the water when it hits the
> radiator sprays the engine and of course the distibuter and shorts
> everything out and the coach stops. The whole thing cools off since it
> can't run until you pop the cover and dry everything off. Is
> this about right?
> >Roger
> >I must say that none of us can answer that question for you. First
> >we must determine your Fear level (pucker factor) and then your
> >Dream level (smile factor). What do you think about when you drive?
> >Do you listen to the stereo or the engine? Does a single miss fire
> >on a 5000 mile trip cause you further hemorrhoid problems or do you
> >dismiss it as a fly in the gas you bought? Have you installed
> >a little mirror on each side so you can watch each front wheel
> >bearing? Now you must also must understand that I have only
> >driven me GMC about 50 miles. I am rebuilding my dream GMC.
> >It cant be worse than my LeSharo. ( It has even turned me from
> >a stereo listener to an engine listener)
> >>From my perspective number one priority is to get all of the leaks
> >stopped. Understand I bought mine at a junk yard. Just put in a
> >door seal from gateway and it has stopped the floor from getting wet
> >around the door. Will be sending Patrick pics of what I found out
> >about wet cockpit floors in the morning.
> >My next priority is I like to cook at campouts. Also I have no
> use for the
> >couch. I therefore am going to extend the kitchen counter and put in
> >a desk where the couch is. I have been offered several consulting
> >jobs when I retire so this seems like an upgrade to me.
> >With my back there is no way I could sleep on that thing they
> >call a bed in the back of the coach. Took all of this out and I am
> >putting in a nice flat piece of plywood. Add a good mattress and
> >I will be able to sleep there. Now that is an upgrade.
> >I would like to do some dry camping. I have only done one night in
> >my present rig. But this sounds like fun. All alone on some nice little
> >lake some where. I will put in a Smart charger 40 amp critter. I like
> >the looks of what I see.
> >I am also putting in a microwave and an inverter. Never thought I
> >would need a microwave but now my mind has changed. It is
> >fast and sometimes that is nice. (See cant even make up my own
> >mind let alone yours)
> >Since I like to cook and I also smoke there is no way I am going
> >to add one of those soft fuzzy headliners to my coach. Not even
> >carpet. I have put in a plastic headliner of the same material as
> >the endcaps. NO the people who put in soft fuzzy headliners are
> >not wrong. It just does not work for me-------and this is my coach
> >just like the one you get will be yours.
> >Now this pure silly. I have studied the door switch on the entrance door
> >and I ask some questions in here and I came up with a plan. I have wired
> >the door switch so when the door is opened it turns on 4 nice lights
> >all over the front of the coach. Is this an upgrade-------heck I
> dont know
> >but I love it. Oh yes I also wired in a switch so the lights do not come
> >on when the door is opened. This is fun!!!
> >Now here is a crazy idea for a crazy upgrade. I have installed
> >a water line from the kitchen to the front of the coach. I am going to
> >install a lawn sprinkler on the grill. If I am pulling a long
> hard grade and
> >the old girl starts to overheat--------hit the switch and the
> radiator gets
> >a shower from the water in my tank. Silly right ---------oh I dont know
> >I love it.
> >I want to operate my laptop on the desk that I am making so
> >I have run a clean circuit up to just behind the drivers seat.
> >I have also put a clean circuit to the cabinet in the bedroom.
> >I will put a DC TV there.
> >Roger Live you dreams not your fears. Yes, your fears will happen.
> >Your dreams will only happen if you make them happen.
> >Take Care
> >Arch
> Tom & Marg Warner
> Vernon Center NY
> 1976 palmbeach
