We made it back from Delaware, Ohio successfully witnessing Eclipse Totality. Haven’t tally’d the numbers yet but coach ran well climbed most of the hills >50 mph, tried to keep vacuum in the yellow, but ran at ~5 psi for some. Probably just over 1000 miles. Burned about 3 qts oil, but this could be from all the downhill high vacuum deceleration, no smoke whatsoever. Having a small issue with engine battery draining since I re-did all my grounds/cables. This was while plugged in and boost switch off.
