New-rebuild --- oil burner
thomas g. warner
1,863
Gene if it were mine I would do two things:
1. check to make sure that you are not overfilling your engine.
2. run a compression check on all of the cylinders, see if they are within
specs
3. Hook a vacuum gauge to a manifold connection and check for correct vacuum.
4. Replace the transmission modulator
If this doesn't work than I would suspect that when they installed the rings
they did not properly align the ring gaps.
>-- [ From: Eugene Fisher * EMC.Ver #2.5.3 ] --
>NEW-REBUILD - OIL BURNER
>I also have a new-rebuild oil burner
>At 5000 a 1 quart every 300 miles
>At 7000 it was 150
>Lets just say I was not all smiles
>No leaks on the ground
>No smoke from the pipe
>The old girl is using more than her share
>Now I have a gripe
>So now we start the search
>First change the PCV creep
>That has never worked
>At least it was cheap
>Change the fuel pump
>It might be leaking from the case
>There went a good fuel pump
>man what a waste
>Pull off the PVC tubes
>to check for smoke
>Says our good buddy cdoublday
>One last chance before I choke
>One if by land
>two if by sea
>NO SMOKE !
>So its new heads for me
>Last chance before the lower rebuild
>Time to see Mondello
>If I can get off jury duty
>Then off I will go
>If this does not do it
>Then rebuild the whole damm thing
>I have to get going
>There is Mexico in the spring
>gene
>Gene 76Palm Beach /Or/CA
>GMC Technical Information
>http://www.california.com/~eagle/
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
