Emery,
Timely advice.
> In a message dated 7/28/99 5:35:33 PM Eastern Daylight Time,
> not fit any more. What is the solution to getting it on properly and to
> get it to stay. >>
> Chuck -- I assume that you have the white rubber trim that fits into a groove
> in the aluminum channel around the window. Older GMCs have plastic trim
> pieces that fit around the window. I have found that the easiest way is to
> heat the trim in hot water and then either use a slightly soapy water
> solution as a lubricant or silicone spray. Work the bead into the groove and
> tap it in place with a small rubber mallet or plastic hammer. If you stretch
> it slightly the ends should meet when you get around the window.
Emery,
Are you saying to slip them in place sideways or slide them from the end?
Sounds like you did this job before. Did you paint the trim pieces and if you
did, how did that hold up with the hot water? I painted mine with vinyl spray
paint.
Richard Waters '76 PB, Troy, MI
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
