For those of you considering swapping out the original 12/120V fridge:
We just replaced our original unit with a new Norcold 641-3 3-way fridge.
The Norcold came from RV Parts in Sunnyvale, Ca for $949 - including the
trim panels. If you choose to go this route be careful with the part
numbers. The dealer had a different model number based on how he ordered
units.
The new fridge is slightly taller than the old one and a bit narrower
(about 1/2 inch). The old fridge came out pretty easily, but the plywood
behind the unit was in horrible shape. Since I didn't have the time to do
the entire installation myself, I don't have pictures from every step. The
final pictures will go up on my site this weekend sometime. Installation
was a bit more than a day's time to build the new baffles, install new
framing, and close the side gap with a piece of laminated material that
more or less matched the Palm Beach trim. The depth of the new unit was
perfect - lots of room to complete the installation. Clearance at the top
for the exhaust vent was very close. In addition to the woodworking, a new
12V line and propane line had to be installed. The existing 12V line is too
small for the increased current draw.
Norcold also makes a 2-way that is about $100 cheaper. We decided to go
with the 3-way because we drive quite a bit and wanted to save on propane
usage and hassles during refueling. If ice makers are your thing, Norcold
also has ice maker options.
Henry
Soquel, Ca 95073 / IP reviews
fax: (408) 462-5198
units.
Henry
fax: (408) 462-5198
