It really is a neat engine, with double overhead cams and 4 valves per
cylinder, very efficient. But it's only about 240 cubic inches; I doubt it
would do well at all in a motorhome application because of the
weight...Possibly, with proper gearing. It makes on the order of 300
horsepower, but torque won't be much because of the small size.
Travis
- -----Original Message-----
To: gmcmotorhome
Date: Saturday, March 27, 1999 7:20 PM
Subject: Re: GMC: New engines and trannys and brakes for the GMC
>I know that the 455 is a terrific engine, but have been thinking about
>buying another coach and trying to stuff the Cadillac Northstar engine into
>it. Boy would it look terrific. that is one beautiful engine. 200MPH land
>speed record with it, maybe.
>>Tom
>>It sorta will (bolt up to the transmission, that is.)
>>Obviously, the crankshaft and the torque converter's centers must be on
the
>>same axis. This is determined on both the Chevy and the BPO
>>(Buick/Pontiac/Olds) and Cad applications by a dowel pin on each side. The
>>pins are pressed into the block and the bell housing of the transmission
>>fits over them. There is a 3/8 24 bolt above and below each of the dowel
>>pins, plus a couple more bolts along the top of the bell housing.
>>The dowel pins and the two bolts on each side nearest the dowel pins will
>>line up just fine between an olds/cad transmission and chev block, and the
>>shafts will be in alignment. The torque converter will bolt nicely to the
>>chev flex plate (flywheel) if you have the right one.
>>The only problem is that the bolts (4 in all) along the top of the bell
>>housing don't all line up. It wouldn't be a major task to make a plate
from
>>say 1/8" steel to interface the two and give the bolts a place to go; such
a
>>plate may already be available commercially. But since the dowels and 4
most
>>important bolts do line up, it would be a very easy project.
>>Of course, having done that, you'll then have to adapt the engine mounts
and
>>do a lot of engineering to make all the accessories work. Probably not a
>>terribly difficult job.
>>The 454 is a terrific engine and would be a very good choice if you were
>>starting from scratch, but, frankly, the 455 olds is an extremely good
>>design also and since parts are readily available my advice would be to
run
>>it forever. But I'd like to see one that had been changed over just so I
can
>>say I've seen it. I've had some good times wringing out 454's...and L/88
>>427's, etc. I am a great fan of the big block chevy.
>>Travis
>>From: Thomas G. Warner
>>To: gmcmotorhome
>>Date: Saturday, March 27, 1999 6:13 PM
>>Subject: GMC: New engines and trannys and brakes for the GMC
>>>someone posted information ashort time ago on installing a chev 454
vortec
>>>engine into the GMC. At the time I was not interested but am now having
>>>second thoughts. Does anyone have any info on how to do it? Will it bolt
to
>>>the toro tranny?
>>>Looked at a 1996 Cadillac with the Northstar engine and tranny and boy is
>>it
>>>nice. Would it ever be nice in a GMC? wonder if that would fit. what an
>>>engine and very tough
>>>Has anyone came up with a GM disk brake setup from another GM vehicle
that
>>>can be installed on the rear bogies easily?
>>>Time to look for another project.
>>>Tom & Marg Warner
>>>Vernon Center NY
>>>1976 palmbeach
>Tom & Marg Warner
>Vernon Center NY
>1976 palmbeach
