I recently installed a rebuilt carb on my 455 GMC. The old set up was the
original carb however the fuel pump had been altered. There is no mechanical
pump on the vehicle, with fuel being delivered via a Carter electric pump. I
know, from reading other posts that many feel this is a questionable setup,
but it has worked for me for many years without incident.
My problem is that once I installed the new carb, I noticed a poor idle at
slow speed, as if the engine was flooding. When I took off the air cover to
look, I noticed that the volume of fuel is too great and is actually
flooding over the top of the carb onto the intake manifold. YIKES!
The new carb was from a source I won't name here, but was claimed to be
perfectly tuned and adjusted for this application. Being a novice mechanic,
especially when it comes to fuel systems, I was hoping that no adjustments
would be needed, and paid extra to hopefully insure this.
What on earth is wrong here. I don't believe it is a pump problem, as the
set up is identical to that which I used for many miles without a problem.
Could it be a sticking float or something? Any insight would be most
appreciated. As is customary, this comes up just as we are planning to head
south later this week. ARRRRRGGGGHHHHH!
I anxiously await any help anyone could offer.
Sincerely, Tony B.
Sincerely, Tony B.
