I very seldom hear that owns have changed the FD lube. I change mine ever=
y 30,000 miles. That comes out to every other trans fluid/ filter change. O=
ils cheep. After getting the trans in Barb's 73 GMC. I pulled the FD cover =
off at the end of the day so it could drip all night. And that it did. The =
gear lube came out like maple syrup on a 10 degree Winter day in Iowa. 14 =
hours later. Still slowly dripping. And way be on black. It had mineral bas=
e lube in it. Can't get it all out. So I stayed with it. It did the job for=
44 years, and 200,000 miles. No reason to change at this point. Personall=
y. I wouldn't change to synthetic unless you can clean ALL the old lube ou=
t for sure. So. When was your FD lube changed? If you change the lube. Chec=
k with those here about the special gasket with the vent passages. Then how=
to find/clean the tiny hole in the cover. You need no mechanical skills to=
do this task. 1/2" socket or wrench, drain container, spray gasket adhesiv=
e, scraper of some kind/ single edge razor blade, a solvent to clean gasket=
area, and 2 qts of gear lube. Bob Dunahugh
