I know that you start at the source, and protect for the worst case
scenario. Human contact with that source. Fusing, circuit breakers, wire
diameters and insulation thickness all factor in. Protect people first,
then facilities.
Salem, Oregon
On Wed, Dec 25, 2019, 12:23 PM tonka6cuda6--- via Gmclist <
> Jim i've been a mechanic now for 40 years with a back ground in racing and
> fabrication....i am not an electrician nor do i play with 120/240v AC stuff
> very often....the stuff i currrently play with is 600 to 900v and over
> 350amps DC.....hence my question here about a generator that is going to
> output
> 120v - 50amps AC when everything is wired for 30amps AC.....common sense
> says everything should be fine as long as i have a 30amp breaker between the
> coach and the generator but i just want options and opinions.
> > Voltage at batter does no mean much.
> > Lot of the connectors are corroded.
> > You need. Real experience to know these things.
> > That is the difference between a degreed engineer and a technician with
> > experience.
> > I put aside my degree and rely on my technical experience since my teens.
> > On Wed, Dec 25, 2019 at 11:14 AM tonka6cuda6--- via Gmclist <
> > > So i was working on wiring up my Honda EV6010 yesterday and it dawned
> on
> > > me that its a 50amp unit [no 30/20amp split like the later ones] but
> the
> > > coach is set up for 30amps.....what would you do? And if you were
> going to
> > > change something what would be the best course of action to do it.
> > > I may be thinking about this to hard and it really might not matter
> but im
> > > not taking a chance when there is such vast knowledge and expertise
> out
> > > there to bounce this off of.....
> > > Rich Mondor,
> > > Brockville, ON
> > > 77 Hughes 2600
> > > _______________________________________________
> > > GMCnet mailing list
> > > Unsubscribe or Change List Options:
> > Jim Kanomata
> > Applied/GMC, Newark,CA
> > jimk
http://www.appliedgmcrvparts.com
> > 1-800-752-7502
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
