I managed to get up early enough
Thanks for the opportunity to chat,
Jim.
As it may be of interest to others I'll summarize what I came away with from
the discussion.
A "stretch it's life (genset) a little longer suggestion" was to add an
external AVR (Automatic Voltage Regulator). This was predicated on the
genset being ble to maintain a steady RPM and mine seems to be doing that.
I.e. I can set the hertz and it's an acceptable 125 volts if I keep a load
of a heater or the AC on it. And it stays acceptable even when adding more
load, so I'm considering it to be a steady rpm, though maybe not the right
rpm.
Being 'really' reluctant to spend money to repair/overhaul the 22 year old
genset that has 'many' hours on it, my ears really perked up when he
mentioned that he'd done a couple of conversions of a current 5kva Onan to
fit the power drawer, i.e. no having to sacrifice/scrounge for extra space
back there.
Hopefully you had a chance to get some elaboration on both of these
possibilities and perhaps you decided he's a keeper
I'd definately be interested in either or both of these solutions. If I can
stretch the current gensets life a little for a couple of hundred (adding
the AVR) it would give me time to save up for the 5kva conversion
. I
would've replaced the genset long ago but everyone always wanted the space
of the drawer and behind the drawer and my big house battery lives there and
I ain't giving that up. There has to be a better way.
Thanks again for the opportunity to chat with the Tech. FWIW, it was a good
chat
I guess in the meantime I'm back to regulating the juice with an electric
heater. A/C doesn't get too much use in my neck of the woods
. At least
the genset is working again.
Heinz
BTW Jim, the time delay module in the shore/genset switch over relay worked
just fine as a replacement in my electrical panel and the relay went into
the spares box as it too will be a suitable replacement.
BTW-2. The no start at all problem was a foil burnt out on the circuit
board. Bridged it with a piece of wire and all is well, or rather it started
after that.
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of Jim Bounds
> Sent: Wednesday, July 15, 1998 11:23 PM
> To: gmcmotorhome
> Subject: Re: GMC: Need some help to set the GenSet please
> Heinz,
> No, the PC board only controls the B+ to the ignition. It
> turns on/off,
> monitors oil pressure and switches power to ignition between
> battery and
> internal alternator circuit.
> If you would like to get some input on your problem from a
> level 3 Onan
> tech., give me a call at the shop before 10 AM and I'll let you speak
> with one. No, not me, I have been contemplating expanding my
> work force
> and will be interviewing an Onan tech. tomorrow morning,
> maybe you could
> help me see how well he can diagnose over the phone.
> Jim Bounds
www.gmccoop.com
> > Got my GenSet (6.5kva power drawer) running again but I'm
> having problems to
> > get the correct output.
> > If I set for 60 cycles my noload voltage is 144, with A/C on 125.
> > If I get the no load voltage to an acceptable level then
> cycles are too low
> > and of course even lower when load is applied.
> > Does the circuit board have anything to do with this or is
> it strictly the
> > mechanical adjustments as per user manual.
> > Any help/suggestions greatly appreciated.
> > Heinz
