Greg,
An inverter of 1200 watts or so is enough to run most smaller appliances
and will not require extensive primary power supply wiring. I designed
ambulances for a year or so and we installed 1200 watt Tripp inverters
which worked out very well.
I would agree that isolating the inverter system from the gen./ shore power
circuits is a very good idea. No one can make a mistake and toast
something besides this will make both systems more reliable. The inverter
will proboobly call for an 8ga. pos. & neg. wiring, the larger the guage
the better. I would use at least 6 ga. wiring and make the runs as short
as possible.
I picked up a really heavy group 7 deep cycle marine battery at Discount
Auto parts that would work great for you. I don't remember the # but it
will be the heaviest one on the shelf.
An inverter system like you describe is a great idea especially if you are
in an area where the roof air is not needed.
If you need help sourcing the inverter give me a call and I;ll round up
some prices for you.
Hope this helps,
Jim Bounds
>Hello all,
>Looking to set-up my coach with a large capacity inverter, probably
hard-wired
>to the coach battery (as opposed to going thru the cigarette lighter, which i
>believe drains the engine battery). Just looking to get a good amount of
>power without needing to run the generator (installing a mini sound studio!).
>I know that there are 1200 watt inverters on the market, and i'm wondering if
>anybody has heard of anyone using one even larger than this, or is this not
>recommended? I'm probably going to add a second coach battery, and sit it up
>front next to the engine battery, but unfortunately the battery tray is not
>large enough to fit the 12v (deep cycle marine) battery next to the engine
>battery. any recommendations on where to get a larger tray? I have a '78
>Eleganza II, and i know some of the earlier models came with the larger tray
>up front.
>I'm probably going to have this system supply a few dedicated 110v
outlets, as
>opposed to wiring into the coach 110v outlets. I'm not an electrician, but i
>have a friend who can do all this for me, once i decide the course of action.
>Any recommendations on inverter size/brand, battery tray, wiring schemes; and
>retail referrals or warnings greatly appreciated! thanks!
>Greg Weber
>'78 Eleganza II
>Boston MA (but soon hittin' the road!)
>GoneMad5
as possible.
Hope this helps,
Jim Bounds
>Hello all,
hard-wired
>up front.
outlets, as
>Greg Weber
>'78 Eleganza II
>GoneMad5
