Been there tried that Scott. The furnace is almost the exact height of the
opening even after I routed the bottom of it out even with the inside bottom
rail. If you remove the 4 1/2" base and try to install it flat on the floor
it takes a gorilla and lots of strained joints to put it in since it will
only slide in when it is perfectly level. I got all but 2 inches of it in
when I gave up on that method. If it had to be serviced it would be even
worse to get it out.
Finally got the problem solved. Found out from cinnabar that the aluminum Z
is not a structural memberand is only about a yard long and bolted on both
ends. I am going right now to give it another look before deciding to
either cut and modify it or remove it completely like they do when
installing the suburban. By the way Cinnabar does not follow their own
installation instructions either. In addition they use the aluminum flimsy
4" duct for the installtions.
>In a message dated 1/19/2000 8:51:19 AM Eastern Standard Time,
>> I don't know if my coach is one of a kind (1976 Palmbeach) but it has an
>> aluminum Z channel installed across the back of the coach startting from
>> somewhere behind the sink module and ending near my sofa. Can it be cut
>> out??????
>Tom!
>I went out and looked at mine--75PB--I also have a Z bar at the back.
>Looking at your pictures and my solaire--your "new" base seems to be about 2
>1/2 inches higher than my solaire. Could it be your base is to high? I have
>a website http://me
>mbers.aol.com/adohen2/page/index.htm with some photos-- lots of images
>but the ones closest to your problem are :
>http://members.aol.com/adohen2/page/images/22_19.jpg
>http://members.aol.com/adohen2/page/images/27_24.jpg
>Scott INSIDE GMC
>PHOTOS(sound on?)
>> out??????
>Tom!
>a website http://me
>Scott INSIDE GMC
>PHOTOS(sound on?)
