Usually, whenever someone experiences a need to either repair or
overhaul/rebuild their engine, often time is of the essence and they also
need help to select the appropriate parts. So where do they go, why of
course, the GMCnet. Periodically someone asks and others respond. And this
process continues to repeat itself down the road.
Seeing Brent mention Clevite bearings below, in conjunction with engine
overhaul/rebuilding, got me to thinking that it would be a good idea to
establish a recommended listing of parts and brands applicable to the
foregoing. Notice I mentioned "recommended listing". This should then be
given to Patrick to post on his web site for the benefit of others to access
and utilize as well as well as offer it to the GMCMI to incorporate into
their Parts Index. Why make owners have to plow old ground when we can do
otherwise.
First we need to develop the type of parts listing and then list the
applicable brand(s).
Anyone feel this has merit??
To start out, lets build the list. I'll initiate and anyone else feel free
to add to it or fill in info. Do so by inserting parts types in
alphabetical order in the listing.
Engine Overhaul/Rebuild Parts Recommendation Listing
Type Brand Part Number
Remarks
Camshaft (403 cid)
Camshaft (455 cid)
Camshaft Button
Distributor
Exhaust Valves (403 cid)
Exhaust Valves (455 cid)
Headers Doug Thorley 355Y
Intake Manifold (403 cid)
Intake Manifold (455 cid)
Intake Valves (403 cid)
Intake Valves (455 cid)
Main Bearings (403 cid)
Main Bearings (455 cid)
Pistons (403 cid)
Pistons (455 cid)
Rings (403 cid)
Rings (455 cid)
Rods (403 cid)
Rods (455 cid)
Rod Bearings (403 cid)
Rod Bearings (455 cid)
Thermostat
Water Pump
Now it's your turn!
Paul Bartz
Sent: Thursday, November 18, 1999 2:36 PM
Subject: Motor Rebuild
The Clevite 77 and its close relations (tri-metal type bearings with copper
underlay) are notorious for eating cranks. They're nearly universal however,
usually its all you can get. Drag racers love them, because they're very
tolerant of heavy pounding, but they are not suited to passenger car
engines. Best bearings I've ever seen thus far are Moraine '400' type, which
are aluminum faced, tin plated steel back. Almost every GM engine since 1962
has used an aluminum bearing from the factory, and they are extremely
reliable in service, and seldom at the root of a problem.
otherwise.
Remarks
Camshaft (403 cid)
Camshaft (455 cid)
Camshaft Button
Distributor
Pistons (403 cid)
Pistons (455 cid)
Rings (403 cid)
Rings (455 cid)
Rods (403 cid)
Rods (455 cid)
Thermostat
Water Pump
Now it's your turn!
Paul Bartz
