More Onan ignition development
jim miller
Member
Mar 31, 2008
546
12
18
My experimentation continues on alternative Onan ignition systems. The two-magnet Pertronix 1121 described in one of my earlier postings seems to be a very workable solution if one wants to stick with the OEM series-secondary coil and it definitely produces far less stress on the ignition coil than the 1181 module that has traditionally been used. The electronic triggering via the Pertronix also eliminates the misery that comes with corroded breaker points and their condenser. The spark voltage with this system remains low, however, due to the series secondary of the coil and as such the plug gap must be kept at 0.020 to produce reliable ignition.
Moving forward three decades from the 1970s brings me to logic triggered one-coil-per-plug systems that integrate charging, firing and dwell-limiting circuitry right on the coil assembly - in this case using GM/Delphi coils for LS2 engines that run $20-$40/ea depending on whether you get the real Delphi ones or the knock-offs from China. These coils make life very easy since they produce a very hot spark and the system designer does not need to deal with triggering circuits, flyback voltage clamps and other real world complications. The DIY engine controls community likes these coils since they produce a big spark and are easily to interface - you raise a 5V logic signal to charge the coil and then drop it to fire the plug - and this simplicity is why I chose them. I figure Delphi knows far more about the subject than I do - and the less circuitry I have to design the better.
I selected a multi-purpose Honeywell gear tooth sensor that has found applications in the industrial control world as well as in the automotive world for crank and cam position sensing. Based on its spec sheet I machined a trigger wheel that had a notch of the correct angular size to charge the coils for an appropriate duration (4ms) and then to fire them. I am using plugs that have their gaps opened up to 0.040” which would never have worked on the OEM system.
Pictures of this work are at: http://www.jcmco.com/gallery/album31 http://www.jcmco.com/gallery/album31
It has amazed me how well this unit picks up instantaneous load as applied by my load bank. I can go from a no-load condition to 5kW nearly instantaneously and the engine does not stutter, hunt or otherwise stumble around AT ALL - but it sure does change the exhaust note from a nice drone to a gutteral groan when hit with nearly full load. I’m really happy with the way this system works and will continue with its development.
—Jim
Jim Miller
1977 Eleganza
1977 Royale
Hamilton, OH
How about a video so we can hear it run?
I have several but my ancient photo gallery software has no idea what to do with the enormous video files that come out of my phone!
—Jim
Jim Miller
1977 Eleganza
1977 Royale
Hamilton, OH
Nice work, Jim. Moving to modern equipment should be a major improvement.
Eespecially that load transition improvement, which was always an annoyance
to me when I ran an Onan -- even my cheap TroyBilt noise box is better at
that! :-)
Upload them to Youtube - Youtube knows how to handle those files.
Best regards
Peer Oliver Schmidt
PGP KeyID: 0x4196BF22
'76a 26' Eleganza II - Virginia, US
'73 23' Sequoia - Schleswig-Holstein, Germany
Jim,
I had thought of experimenting with the wasted-spark coil packs as used on my Pontiac G6 with a 3.8L V6. I didn't get far when I discovered their own
built-in "igniter" electronics. I've found people on-line who have opened the housing to bypass the internal electronics. That way the coil pack could
be used with the existing points or Pertronics module.
After reading your post, I though you might like to try them to reduce parts count and wiring.
Bruce Hislop
ON Canada
My 90s John Deere 425 with water cooled VTwin Kawasaki uses coil per cylinder ignition with a very short plug wire coming from each coil. Very good
system. Sounds like you have it covered but this would be another proven system to "steal" from for a 2 cyl engine.
John Lebetski
Woodstock, IL
> I had thought of experimenting with the wasted-spark coil packs as used on my Pontiac G6 with a 3.8L V6. I didn't get far when I discovered their own built-in "igniter" electronics. I've found people on-line who have opened the housing to bypass the internal electronics. That way the coil pack could be used with the existing points or Pertronics module.
Hi Bruce, thank you for the suggestion! I believe that you are referring to the GM DIS (“Distributorless Ignition System”). I, too, had considered it for the Onan but I discarded it because I could find no factory made baseplate designed to hold a single coil - there are only 2- and 3- coil models. The electronics probably are not that difficult to figure out but I wanted to avoid developing a new single coil mounting baseplate with the associated potting and connectorization issues.
One thing I am keeping in mind when doing the Onan ignition work is to keep the homebrew part to a minimum for reliability reasons. GM, Delphi and all the others have worked very hard to iron out issues that I may not have even foreseen so I attempt to leverage their work as much as possible. Also - there is precious little space on the Onan in which to install new gear!
—Jim
Jim Miller
1977 Eleganza
1977 Royale
Hamilton, OH
Very impressive Jim.
Jim saved my Onan when I was a new owner 5 years ago, for which I will ever be grateful.
I'm no expert but I have been able to share some of the knowledge I gained and help a few others get their Onan running.
I'm a bookkeeper, not a mechanic or engineer.
1978 GMC Royal
Eastern Pennslyvania
1968 Chevrolet C20 396 Camper Special
1969 Chevrolet C20 Camper Special
1985 Buick Electra Park Avenue
1992 Camaro 25th Anniversary Heretage Edition Black
Will you make a kit available, or at least the tone wheel?
--johnny
Braselton, Ga.
Hi Johnny,
I do plan to make kits available. There is a little more refinement to be done on the current approach plus I’m working on another design that may be even easier to install if things work out the way that I think they will.
Right now I’m running the Pertronix 1121 with the 2-magnet tail shaft wheel on my “daily driver” GMC and the dual-LS2 coil+Crank position sensor on my test unit.
—Jim
Jim Miller N8ECI
Hamilton, OH
1977 Eleganza II
1977 Royale
Very cool heard that you are the Onan Guru love reading your updates
'78 Palm Beach. car nut new to RV'ing 26 ft. 403 rebuilt in 2018, rebuilt tranny in 2014, Dave Lenzi knuckles & hubs, yada yada yada OEM chromed
wheels,Green Brady Bunch stock
