Misc Parts
I keep a list of parts I'm looking in Google docs - with photos to make sure when I send the list to other people, that we're talking about the same thing. Here's a quick list of parts I need, with details and photos in the Google document if you need clarification (https://docs.google.com/document/d/1J-tX9M97maBVIcizBbKmeosigZRriANF8qGPOs2VxJM/edit?usp=sharing).
1) Both upper fan shroud brackets with bolts, washers, etc.
2) One screw that secures engine hatch to floor
3) One U-nut that the screw above goes into
4) One washer fluid squirter nozzle
5) One washer fluid dash switch
6) One cardboard woodgrain panel for entry door
7) Coachmen fresh water holding tank door
8) Two doors (and hardware) for vacuum cleaner compartment (under fridge)
9) Bedding locker end cap under rear window - need both sides
10) Two newer-style window latches for window over dinette and across from the dinette
11) Cruise control linkage: namely, the rod that connects to diaphragm with a beaded chain on it, along with whatever connects that to the carb
Any help would be much appreciated!
Thanks,
Greg
I think I have that cruise control stuff in (11)
Are you going to MI rally in a day or two? I'll bring it along
