All this talk of tires.
I guess its time to jump in.
When I got my 73 Sequoia it had load range D tires on the original rims. I
discovered that there was a problem with using radial tires on the original
rims after one of them failed. Fortunately it was just a small crack that
caused a slow leak. Because I didn't ignore it I probably saved myself a
lot of grief. Fortunately I was able to find a good set of used radial
wheels.
I still did not know about the load range D recall so I just remounted my D
tires on the new wheels. A couple years ago I noticed that the belts where
separating on two of them. So it was time for new tires. After making a few
phone calls (I didn't know about this list at that time), the consensus was
to use Michelin XPS Rib Tires. They where not easy to find and where very
costly but they look indestructible. I run them at 70psi (cold) and the
ride is only slightly harsher than my load range D tires at 65psi.
What I am wondering is; are these good tires for the GMC? Is there anyone
else out there using them and have you experienced any problems?
I have seen some problems with Michelin's mentioned on the list but I am
wondering if any of them where the Michelin XPS Rib tires? My understanding
is that the XPS Rib tires have a stronger sidewall so as to be able to
withstand the higher side loads and flexing they experience on the GMC.
Dave
73 Sequoia
wheels.
Dave
73 Sequoia
