Material Spec for Aluminum Body Panel
PeteSr
116
35
28
Does anyone know what the alloy of the aluminum side body panel is? The assembly manual does not seem to list it, and I wouldn't expect it to. Is there a spec anyone knows of? 6061, 3030, or what? I am looking at changing from the plastic fridge access panel to the smaller aluminum one and will need to weld in a transition piece. I can measure the thickness of the body (it measures at 0.062" average in that area).
OK. Thanks after investigating deeper, I have concluded that a weld repair is essentially not feasible. Thanks to Christo & Kerry Pinkerton’s excellent posts.
I’m a pilot and aircraft owner. So I will instead make an aviation flush patch using countersunk rivets. That along with a little JB weld filler (or perhaps some other yet to be determined filler) should give me a professional solution.
Reactions: Christo
I thought I would share with the group that the alloy of my 1978 Eleganza II body skin was tested by one of my company’s Level 3 NDE technicians using a Niton fluorescence X-Ray gun.
The skin’s alloy is AA 6063. It is not a 5000 series as previously thought. Also, the gun cannot tell the temper of the alloy.
An interesting note is that alloy is considered very weldable. But being 1/16” thick (0.063”), probably will warp.
