Master Cylinder replacement needed / soundproofing / hatch
heinz wittenbecher
1,470
> > adding some more genset soundproofing
> Hi Heinz!
> What type of product are you using? Are you putting it over the box
inside
> the coach? Thanks for updating your website all the time, I've got to keep
up
> with what you will do next
I had some heavy foam/foil on one side left. It's about 1/2 to 3/4 inch
think.
I'm putting it on top of the box inside.
Don't know if it'll make any difference but since I had it and had the top
off.... you know the rest of the story :-)
I have to redo my hatch cover so that it locks under the lip again.
Will be looking for some material then and also something to use as doorseal
that'll take the heat.
Any ideas on what to use?
Heinz
Heinz
