Main black tank valve not completely closing
RF_Burns
Super Moderator
Staff member
Sep 7, 2008
5,167
1,364
113
Ontario Canada
So my black tank valve doesn't completely close. I can't get the retaining clips to snap over the handle. I'd say its less than 1/4" open, although
it doesn't seem to leak. I'm thinking there is some crud built-up in the end slot where the blade closure fits in.
Is it possible to remove the valve's shut-off blade out of the side of the valve so I can get a stiff wire in there to clean it? I'm hoping I don't
have to pull it all apart to get to it. :roll:
Bruce Hislop
ON Canada
You have to pull it apart.
Emery Stora
> Bruce Hislop
> ON Canada
> although it doesn't seem to leak. I'm thinking there is some crud built-up in the end slot where the blade closure fits in.
> don't have to pull it all apart to get to it. :roll:
Bruce,
I am working at remembering how this all goes together. If it is an original Thetford valve, then it has to split at the face side of the entire
body. And that can't happen with the valve installed as it is also held together by the mounting screws. This is not sounding real do-able.
As I remember, what you would really like to do, just can't be done.
There is just no way to get at that.....
You could put a good cap on the outlet, put in some of the pot chemical that has a paper digester in it and fill the tank to the 3-1/2" level. Then
cycle the valve a lot. If you still have the Thetford flange - Katy bar the door - when you remove it...
I have a Valterra outlet flange and have a cover with a garden hose thread that I could work with...
Unfortunately, a Valterra valve just will not go onto a Thetford tank without some serious magic. I have been trying to design an adapter that would
cost less that a new Thetford valve, but it has been much harder than I imagined.
If the pull handle & rod are original equipment, it may be that the jam nut has come loose and allowed the handle to rotate a couple of threads,
preventing the clips from going over the handle. Happened on my 77 Eleganza. Since the valve seems to be sealing, it's a possibility.
Hope that's it... no one likes working on that area of thee MH! John
John Shutzbaugh, Vacaville, CA, ncserv;
77 Eleganza, bought it new, can't blame PO, and
78 Buskirk stretch, "What were we thinking?"
