I have a remote controlled wireless air system in my coach. I have presents
for ride height, as well as tank draining, programmed into my remote
control. When I want to pump my tanks, I push the button, and the coach
squats on the rear, and leans in the direction of the dump station. When it
gets as low as I want, I stop lowering and start pumping. It will drain
both of my tanks completely. When I am finished, I push the button for ride
height. By the time I stow my hoses, I am back to ride height. Off like a
rabbit.
Salem, Oregon
On Tue, Aug 4, 2020, 7:45 AM Jim Kanomata via Gmclist <
> In order to get more of the tank empty one should ust our Clark fitting as
> it is the best design to use to empty the tank.
> We have sold numerous amounts of them and it does get 25% more out.
> On Tue, Aug 4, 2020 at 7:35 AM James Hupy via Gmclist <
> > On Royale coaches, and perhaps others as well, there is a triangular
> space
> > on the drivers side rear of the coach that a mascerator will fit into
> quite
> > compactly, among with its wiring, and plumbing. Only one drawback. The
> > discharge nozzle points towards the side frame rail. I pondered that a
> bit,
> > then got out my trusty 1/2" chuck heavy duty corded electric drill and a
> > metal cutting hole saw, and bored a hole through the frame rail. Then I
> > plumbed through that hole and terminated that with a 90° on-off valve
> and a
> > 1" hose connection for heavy duty garden hoses. I carry a short piece of
> 1"
> > hose, as well as a longer one for less accessible dump stations. It is
> all
> > tucked up neatly out of the way, and nearly invisible. Sure doesn't drag
> on
> > the ground or any place near it. I put the on/off switch inside the
> > generator compartment to keep passers by from switching my pump on, and
> > powered it from my house batteries. Been working for years. Don't know
> how
> > I ever got along without a mascerator before I had one.
> > Jim Hupy
> > Salem, Oregon
> > On Tue, Aug 4, 2020, 7:04 AM Ken Henderson via Gmclist <
> > > Tom,
> > > SOME of your answers: I too prefer to build steel platforms to set the
> > > pump on rather than hanging it -- just my choice. Frankly, I don't
> > > remember at the moment whether I've still got a quick disconnect on my
> > > drain hose -- it's obviously been a LONG time since I've used it if I
> do.
> > > In my case, I've got a long storage tube beneath the left side of the
> > coach
> > > into which the drain hose slides. (It's a piece of the orange
> "conduit"
> > > commonly used when they bury fiber optics for 'phone, etc. -- lots of
> > > scraps of that around any time they install it.) Mostly, that tube is
> > > inside the frame channel, but at crossmembers it passes just beneath
> > those
> > > if there's no hole available for it. Wide tywraps secure it.
> > > The drain hose is NOT corrugated -- I don't like the idea of all those
> > > traps inside. There are externally corrugated ones with smooth
> > interiors,
> > > I think. Mine is just cord reinforced vinyl 1-1/2" OD, IIRC. It's
> about
> > > 20' long, so no need for connectors for dump stations.
> > > Ken H.
> > > On Tue, Aug 4, 2020 at 9:41 AM tom geiger via Gmclist <
> > > > I’ve done a little research on macerator configurations. I’ve seen 2
> > > basic
> > > > methods of mounting the pumps in the pictures I’ve looked at. One is
> > > > using saddle hangars and attach to the underside of the aluminum
> cross
> > > > plates with what I assume are metal screws. I think this would work
> > fine
> > > > for
> > > > the large pipe support but not sure I want to do that for the pump
> > > > support. I like the additional steel plate platform to mount the
> pump
> > on
> > > > so that
> > > > the vibration of the pump will be absorbed by its rubber mounting
> feet.
> > > I
> > > > do like adding the gate to the pipe branch leading to the pump to
> allow
> > > for
> > > > service or replacement of the pump. I do like the idea of using the
> > > > larger ribbed hose on the discharge side but wonder how the
> connection
> > is
> > > > done
> > > > for the longer discharge hose to the disposal hole at dump sites. Is
> > the
> > > > under carriage discharge hose and outside discharge hose connected
> > with a
> > > > quick connect or a screw on connection? Not seeing any pics on that
> > part
> > > > of it.
> > > > Thanks,
> > > > TG
> > > > Tom Geiger
> > > > 76 Eleganza II
> > > > KCMO
> > > > _______________________________________________
> > > > GMCnet mailing list
> > > > Unsubscribe or Change List Options:
> > > GMCnet mailing list
> Jim Kanomata
> Applied/GMC, Newark,CA
> jimk
http://www.gmcrvparts.com
> 1-800-752-7502
