Macerator help
hdavis
518
I'm now down to 3 major issues to fix:
1. The auto A/C doesn't A/C. I probably need to rebuild the dash switches
for the vacuum system, and the cable end for the temp mixer door has broken
so the door just flaps. I'll try adding a small clamp to that it can be re-
attached to the evaporator housing. Has anybody added a second evaporator to
their coach? I understand that Cinnabar does this but I don't have details.
2. I need to replace the vacuumm breaker on the toilet - any good ideas how
to get at the compression ring holding the plastic tubing onto the toilet?
I've felt around and just can't find a place to squeeze.
3. I've put about 6 gallons of clean water into the holding tank in order to
try the macerator. The pump turns but no liquids come out. Any suggestions?
Do I need more water in the tank?
Otherwise the coach is running fine now. We took it up to the Yosemite area
last weekend. Drove well, climbed all of the hills over 50MPH with the
original final drive. The new Alcoas and G159 tires really made a big
difference in handling!
Henry
Soquel, Ca 95073 / IP reviews
fax: (408) 462-5198
http://www.henry-davis.com
