Low Air Pressure Switch location.
Matt Colie
11,101
807
113
South East Michigan near DTW
The low air pressure light in out coach has never worked. I was hoping to diagnose the issue, but I can't locate the switch. The bulb checks as
good.
Any hints where to look? I can't find an empty air connection or a pair of wires matching the colors....
Thanks
Mine is under the compressor mounted to the radiator support. It's the same switch the compressor uses.
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
Mine powers the light off the compressor feed... it's treally a 'compressor running' light.
--johnny
Braselton, Ga.
"The road goes on forever, and the party never ends" --Robert Earl Keen
On my 1974 GMC 26ft the low air light switch is on the air tank, under the battery tray.
Bob Heller
1974 X-Canyonlands 26ft
Original 455 exc for timing chain,
Rockwell intake, valve covers. 141k miles.
Winter Springs FL
Mine does not even have a light bulb in it but I "think" it is simply a light to indicate when the compressor is running. I also think It is wired to
the air pressure switch switch that turns on the compressor.
my heavily modified 76 Royale has a low pressure switch on the side of the tank which is on the front right under the driver. This is separate from the compressor switch thats on the front of the tank
Sent: Thursday, February 16, 2017 6:33:10 PM
Subject: Re: [GMCnet] Low Air Pressure Switch location.
Don't know about 23' 73s, but in GMC fitted ElectroLevel coaches, there was generally no wire run to the low air light. Many of us used the extra
contacts on the Pressure switch and ran a wire to the light cluster to let us know if the compressor was running. My 77 Eleganza as delivered had no
wire to the switch but had a bulb in the telltale cluster.
John Shutzbaugh, Vacaville, CA;
77 Eleganza, bought it new, can't blame PO, and
78 Buskirk stretch, "What were we thinking?"
