Longer sustained high speeds get very complex. And costly. (Subject title change )
Bob Dunahugh
2,784
4
3
I own a 69 COPO Yenko Stinger. Built from a Corvair. Is the only 69 Stinger ever built. Ford had GM build the car off of the production line. As it was built strictly for off road use only. And couldn't pass any emission, or safety standards. Then shipped to the Yenko dealership for completion. Ford was developing a small race car. That required a 13-inch race tire. That could run in the 130, to 140 MPH range. Ford didn't have a car on 13-inch tires that could operate at those speeds. At just under 8,000 RPM's in 4th gear. It has an idle of 2,200 RPM's. Its power range starts at 5,500 RPM's. With no NOS, or turbo charging. Just 4 way over bored carbs.173 cubic inches. To build the cylinder heads with today's money. Would cost about $28,000. The 4 carbs. $11,000. I've had it on the Talladega track about 9 years ago. With an average lap speeds of 142.2 MPH. 138.4 with the right window down. To listen to it next to the outside wall.
When I got it. I got an odometer statement from Goodyear showing 2234 miles. All these miles were run on Goodyear's 5-mile oval test track in West Texas. At over 135 MPH. This was also the tire test car for the development of the studded snow tire. It had 1/4-inch steel shields in each fender well for these tests. With it's prominance. It has an estimated value of well north of $500,000. But I still road race it on road race tracks around the country. It's been written up in many books, and magazines. Been on the cover of Hemmings Classic Car Magazine. May 2013. Our 78 Royale 403 is the tow truck for the 24 ft enclosed trailer. That I haul the car in.
Bob Dunahugh
78 403 Royale
4 COPO Yenkos. Anb way too many restored convertibles in the collection.
Bob,
Very interesting what was done with the Covair.
On Sat, Dec 5, 2020 at 7:46 AM Bob Dunahugh via Gmclist <
> haul the car in.
> Bob Dunahugh
> 78 403 Royale
http://www.gmcrvparts.com
Both Bob's and JimK's statements are very true.
At one time, I was part of a crew (Not the driver) that raced a Karman Ghia shaped car. At lot of it was like the original and a lot more was not.
When we ran road courses, there were no major issues because the sustained speeds were never that high. We were invited by the New Jersey state
highway department to assist them in some testing of new pavement types. What they needed was cars that could try to stop from speeds in excess of
100. They were hoping for 150. We did the 150 part of their test, and that also clearly indicated that brakes and tires were an issue because it
took me (I did drive that test) most of a quarter of a mile to stop the car.....
I would not have guessed that....
But, due to a mistake on someone's part, we got lined up for a race on a high speed oval. We got the car set up but our driver had not arrived yet,
so I (foolish me) took the car out on the clear track just for a test run. I got settled in and things were ok, then I decided to go for a hot lap.
This was an eye opener. With speeds up in the 150+ range, while stable the cars systems were starting to get out of control, the engine was way hot,
I was starting to loose oil pressure and fuel pressure, at the middle of the last turn, I went to WOT.
The Trap recorded a speed of 168.
I was trying to not be terrified. What instruments I could see were either railed high or nearly and my peripheral vision was gone to a blur.
I shut down and coasted to the pit. That was almost the full length of the track.
Inspectors said that two of the tires were about to fail. The brakes were OK, but the front disks were blue and I didn't remember even using the
brakes. The oil in both the engine and the transmission were badly burned. The transmission oil smelled really bad. The team dropped out of that
race and I never again drove the car at speed. It seems that not only is the machinery stressed by the high loads, so is the driver.
Matt,
what you saw is considered normal.
The stopping distance, reaction time plus braking time, in Germany is
calculated in a way that if you go 230km/h (roughly 150mph), a regular
braking distance is 529m, emergency braking 265m. But if you add the
reaction time to it, the total stopping distance is 600m and 334m.
Now you know, why I only go 200mph on the Autobahn at night, when I can
see for a long distance :-D
Best regards
Olly Schmidt
PGP KeyID: 0x4196BF22
'76a 26' Eleganza II - Virginia, US
'73 23' Sequoia - Schleswig-Holstein, Germany
I have a 1976 SOB 26 ft MH. It's built on a truck chassis and turns 3000 RPM at 60 MPH. I wish it had a final drive that
allowed less RPM at highway speeds. I thought about a GEAR VENDOR overdrive unit but never got around to it. My race car Datsun 510 regularily
got to 7500 RPM. Only special parts in the bottom end were forged pistons. That engine didn't go below 5000 RPM and was shifted at at 7500 PM
and pulled 7500 RPM at the end of the long straight. It was a wet sump and with nothing special to enhance oil drain back. I guess some engines just
don't mind higher RPM, but of course it is a tiny engine compared to an OLDS 455.
DAVE KING
lurker, wannabe
Toronto, Ontario, Canada
