Locking exhaust manifold bolts
travism
222
> These appear to be a lot more complex than the simple little metal
> plate that GMC used (part number: 399423). This just fit under two
> of the standard exhaust manifold bolts and had a couple of tabs that
> just bent against the flats of the bolt heads. The GM part is very
> inexpensive and works fine.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
True, they are a bit more complex, but they will work in applications where
the GM part (known generically as a "French lock" for some reason...maybe a
Frenchman invented them?) won't---i.e. a single bolt on the end of an
exhaust header. And you gotta admire the elegance; I especially liked the
counterbored example.
Travis
> Click here: Stage 8 Locking
>Safety Bolts - How do they work? - (1-800-843-7836)
> Chuck Aulgur, here are the locking exhaust manifold bolts.
> Jerry Lader
> Memphis
Emery Stora
77 Kingsley
Santa Fe, NM
>> Emery Stora
>> 77 Kingsley
>> Santa Fe, NM
>Travis
Travis - you are correct but I like to keep it simple whenever I can.
I have fashioned my own locks before for a single bolt by just taking
a thin metal strap and drilling a hole it in and then bending one end
against a flat of the bolt head and the other end against the part
that the bolt is holding in place.
Emery Stora
77 Kingsley
Santa Fe, NM
> Jerry Lader
> Memphis
> Caddyshack
Some GMCers have reporting problems with keeping their bolts that
attach the axles to the final drive tight. Perhaps these might work
for that location?
Emery Stora
77 Kingsley
Santa Fe, NM
>Em they are more then likely having problems with those cap screws
>because they are not torquing them to 75 ft pounds like the book
>says and they do not use new screws each time.
>tom
That well may be the case. When I put on my 3.55 final drive I
ordered new bolts and lock washers from Cinnabar and I have about
8000 miles on it now and just checked them and they are still tight.
Emery Stora
77 Kingsley
Santa Fe, NM
> In a message dated 08/20/2000 1:16:53 PM Central Daylight Time,
> > The GM part is very
> Emery
> Yup just ordered some. $1.65 from Cinnabar.
> Take Care
> Arch
The local Olds dealer wanted $2.26 and I would have to pay in advance to
get them ordered and wait 2-3 days.
Richard
