Yes this is the right answer. I am also sure it can be reduced to a set of
specs and a drawing of how to do it right. No problem getting it posted up
here.
gene
>Hi, Jerry and Dave
>Good question, Jerry.
>Dave, it seems you have some experience with lift struts, and you made some
>good points on installing these. Our company builds custom sleepers for
Class
>8 trucks, and we use gas struts for lifting bunk platforms, and on tool
>compartment doors with a top hinge. I have worked out several of these
>designs, and I know there are a lot of things to be considered. The strut
>should be placed so it holds the door closed when it is shut (i.e. you must
>pull the door the first few inches before the strut pressure will push the
>door open). There is also a great variety in strut sizes, stroke lengths,
>lifting capacity, and mounting brackets available.
>The point I am making - we need some detailed information from someone who
>has "been there, did that" - that has figured out a setup that works. What
>brackets are used, where are they mounted (measured from the hinge point),
>what gas springs were used, part numbers, etc. If we can get some
>information, I will put together a list of parts, and a drawing with
>dimensions, and make it available on the net for all of us.
>I want to do this to my doors too, but it will be some time before I get our
>GMC back home, and if I had some information before I start it would
>definitely help me.
>Erv Troyer
>Lagrange, IN
>74 Sequoia (in the "burn ward", getting all better)
>------------------------- Original messages ----------------
>On Thursday, June 22, 2000 9:20 PM
>> Has anyone installed gas-charged lift struts on the Onan and LP doors?
>> Jerry Cad. Powered Edgemonte (CADDYSHACK)
>On Fri, 23 Jun 2000 21:55:56
>> Hi Jerry
>> The natural way to install struts is to mount the strut low down on the
>door
>> frame and connect the top end of the strut to the door a few inches out
from
>> the hinge.
>> This makes the door into a long lever and as such it is likely to crack or
>> break.
>> An alternative it to mount the strut on the door frame a few inches below
>> the hinge and then connect to other end far out on the door. The puts the
>> force of the strut far out on the door where there is not much lever action
>> and forces the greater pressure unto the frame which is much tougher than
>> the door.
>> It is hard to picture but the strut is upright when the door is open and
>> upside down when the door is closed. The GM station wagons with the
flip up
>> glass window have thier struts mounted like this. If you get a chance to
>> visit the auto wreckers look for one and check it out.
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
