>-----Original Message-----
>From: owner-gmcmotorhome
>[mailto
wner-gmcmotorhome]On Behalf Of Gcbr
>Sent: Tuesday, June 23, 1998 12:37 PM
>To: gmcmotorhome
>Subject: Re: GMC: Leaks Leaks Leaks(update)
>In a message dated 98-06-22 20:57:56 EDT, you write:
> 3/4 in wide x 5/16 in thick. Self-Stick High Density Rubber Foam
>Westherstrip
> Can be obtained at Home Depot.
> I personally am going to look for the same size but with Butle? rubber.
> elubo
>OK I have failed.
>Well here is a first hand account of the trim thing. I have just put in
>3hrs trying to get that piece of trim off. I have busted 2 phillips impact
>driver heads, wiped out one screw and got 3 out. If you want to get new
>screws they are 10/24 and 3/4 long. The 3 I got out all came out very
>easy. The others I tried (about 8) are not going anywhere. The way this
>seam is set up you had better get closed cell foam. A polycell foam
>is going to hold water and you will have leaks for a week after the rain.
>I did get a piece of the old seal out. IT IS NOT foam but apears to
>be the old black sealing tape they used to use in AC lines where they
>go into the plenum. If I were ever to try this again I would go to my
>local mobile dealer and get some of that caulk strip that they put
>mobile home doors and windows in with.
>The problem is that these are steel screws with fine threads. There
>has been a lot of moisture and dirt under this thing. The screws I got
>out were so corroded it took me awhile to figure out if they were 10/24
>or 10/36. When I got mine it had never been caulked alont the seam
>between the roof and the trim piece. If yours is caulked and kept inside
>yours may come off better than mine. For my part I am going to seal
>mine back down. I had sealed it with C-10 and stopped 90% of the leaks.
>If you are not familair with C-10 caulk it is one of the new hypalon (sp?)
>rubber caulks. It is self leveling-----which means that after you put it
>on it flows down into the crack. You may even have to go back and put
>more on if it all moves into the crack. On the LeSharo I have now there
>is a seam all the away across the back where the alum roof meets the
>fiberglass end cap. They are all known to leak because most caulk
>just will not move that much. My local RV dealer called me when he
>got back from some convention where he saw a C-10 demo. We put
>it on the LeSharo 2 1/2 years ago and it has not leaked once. We
>I am going to go get some more and do it to it.
>Take Care
>Arch
Hi Arch,
A very timely piece,
I found a crack in the roof, Where the Alum Roof meets the end cap. I
will be using C-10 Caulk to fill this crack...Is it paintable? Will it
remain flexable and is it mildue resistant?
I think I'll be able to get the coach on the road by the 4th of july
weekend.
Yipee!!
See ya,
Rob
>[mailto
>To: gmcmotorhome
>Westherstrip
> elubo
>OK I have failed.
>Take Care
>Arch
Hi Arch,
weekend.
Yipee!!
See ya,
Rob
