Bob,
The amount of oil bypassed is controlled by the bypass valve in the oil filter base which according to MM X-7525 it is set to open
at 5.3 to 6.3 psi (ref.: Page 6A-2).
The pressure drop across the oil filter will contribute to reaching that pressure drop. The pressure drop through the filter is a
function of the micron rating (the lower the micron rating the higher the pressure drop) and the surface area of filter medium (the
smaller the surface area of filter medium the higher the pressure drop). Also as the oil filter medium gets contaminated with
particles the pressure drop goes up.
I've Googled Fram PF-25 but can't find the micro rating anywhere; the Wix 51049 is 21 micron. I was able to find the Fram HP5:
http://www.fram.com/media/64582/fram-racing-filter-sell-sheet.pdf and it has a lower micron rating of 18 micron. It is smaller than
the Wix 51049.
Regards,
Rob M.
The Pedantic Mechanic
USAussie - Downunder
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Bob Dunahugh
Sent: Monday, June 19, 2017 11:50 PM
Subject: Re: [GMCnet] Larger Engine Oil Filter
The Fram PH25 that I've been installing on my 403 is 1 inch shorter then the Wix 51049. Thus the 51049 will by passing less
unfiltered oil at the bypass valve. As a note. The Wix 51049 cross references to an AC Delco LAF1881, and a Fram PH11. The Fram
PH25 is 4 inches long. The Wix 51049 is 5 inches long. So how long is the AC Delco LAF1881, and the Fram PH11? As another note. On a
fresh new engine. You need that longer filter so less oil gets by passed. Bob Dunahugh 78 Royale
