KYB Shocks
Got mine from gateway (1-800-654-0374)for $294/6shocks.
They also have the best deal in town for front wheel bearings and seals.
$77. for each bearing + seals and they are the special Timken matched and
properly shimmed bearings.
>Didn't someone mention a while back that they had found a good source
>for KYB shocks? I think Golby has them for around $50 each.
>Patrick
>Patrick Flowers
>Mailto:patri63
>The GMC Motorhome Page
>http://www.gmcmotorhome.com
Arch the NAPA timken bearings are not the correct one for the GMC coach
unless you check the shim clearances. You will note that the part # is
different. The corect bearing has a minimum of 70thousanths clearance.
Already went through that scenario. You could be asking for seized bearings
if you use the incorrect one or if you do not know how to check the
clearance. Cinnabar ahd a bulletin on that some time ago.
>In a message dated 98-05-27 09:39:15 EDT, you write:
>NAPA has the same matched Timken set. Dont remember what I
>paid but thought it was a good deal at the time.
>Take Care
>Arch
If anyone wants a killer deal on the KYBs, call PROAM at 1 (800)
>847-5712, I got the rears for $35 each plus a small charge for shipping.
>Lowest price here in San Diego was $45 each plus state tax. Saved 40
>bucks just on the rears!. Didn't need fronts. P/Ns are:
>Front: KG 5435
>Rears: KG 5436
This is the text from an earlier message on the net. I bought mine from
them.
Russ Bethel
rbethel
> >shipping.
> >Front: KG 5435
> >Rears: KG 5436
> from them.
Thanks Russ! That's the info I was looking for.
Patrick
Patrick Flowers
Mailto:patri63
> Patrick
> Patrick Flowers
> Mailto:patri63
Patrick,
If you can't find KYB shocks, give me a call, I haven't carried them you
for no other reason than no one has asked! They work very well and are
properly designed for the upside down charged requirements of the GMC.
1-877-275-4462
Jim Bounds www.gmccoop.com
