Jacks and Stands ....
dutch marc
90
Hi Everyone (Wanted to start of Hi Guys, but know there there are ladies here as well)
I am getting my tools in order for my 73 GMC, I have a 4T Bottle Jack, and need some input on a Floor Jack. I have a 2T and a 2.5T low Profile.
Since I like the size and weight of the 2 Ton a lot better, would this be nuf for using on my GMC to get the bottle jack in place. I have used the 2T
once when my airbag hose got kinked and didn't want to inflate. I was able to lift the Coach and get the issues solved.
Not sure if there are any other repairs that I might encounter on the road that I would need a 2.5 T or lower profile.
As a Newbie I would also like to know if a pair of 3 Ton Stands are enough to keep the GMC lifted or do I need o go to the bigger and heavier 6 TONS?
Any input is appreciated !
Grtx Marc
1973 26' Canyon Land (Mello Yello) (TZE063v101302)
Los Angeles, CA ('98 NL 2 USA)
For stuff around the house you cannot go wrong in building a set of ramps. They are awesome once you have them and make life much easier. There are
directions on the photo site.
For on the road. I would get a 6 ton two stage bottle jack. Jim K sells them, or Menards.com on line have have it shipped. Torin Big Red Jacks.
The two stage is what you want.
Then get a jack hook Again, Jim K Sells those.
The weight of the bottle jack and hook is less than a floor jack, and Stores well in the coach and will get a corner off the ground even with a flat
airbag. I would not want to mess with anything else.
For stuff around the house when the bottle jack is in the coach. Get a 3 ton or more floor jack. Harbor freight has them on sale usually with a 20%
off coupon. That will also lift a corner as needed.
Jack Stands. Build them, or go with 6 ton units. Rather have more than enough than be squashed.
I have a heavy Royale and the 3 ton floor jack is working to get a rear corner up. 6 ton bottle, no sweat.
77 Royale, Rear Dry Bath. 403, 3.55 Final Drive, Lenzi goodies, Patterson carb and dizzy.
Mid Michigan
I have had my coach weighed a number of years back at the GMCMI in Pueblo. All six wheels have within a few pounds of 200# on them. I use an older
Craftsman 3-ton floor jack to jack it up, the front in the center of the crossmember, and the back under the bogie frames, one side at a time. It is
a chore to lift it at those points even though the 6000# rated jack is 'only' lifting 4000# at those points.
I also carry a 6-ton bottle jack and one of these: http://appliedgmc.com/prod.itml/icOid/955 along with one of these:
http://appliedgmc.com/prod.itml/icOid/1080
I recently had to use the jack hook and the stubby two-stage jack to get the coach up when I blew a hole in an air line, and was glad I had them with
me.
For jack stands, I use a pair of 3-ton units for the front and a pair of 6-tons for the rear.
Just what I do.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Marc, the whole front weighs 4000-4500 pounds, so 2 tons is not enough for
lifting the front of the coach from the center of the crossmember to put on
jackstands. I wouldn't use anything smaller than a 3-ton jack for that, and
mine is 3-1/2 tons.
A heavy coach is about 4000 pounds per rear corner, but that's only when
the coach is level. As you jack up a rear corner, the front corner on the
same side will come with it, so the load will be greater. Again, I wouldn't
use anything less than a 3-ton jack.
A 6-ton bottle jack and a jack hook is very much the better option for the
rear, and probably cheaper, too. The right kind of jack hook can also work
in the front.
Rick "who needs another two-stage bottle jack" Denney
> here as well)
> Grtx Marc
Rick Denney
73 x-Glacier 230 "Jaws"
> I have had my coach weighed a number of years back at the GMCMI in Pueblo. All six wheels have within a few pounds of 2000# on them. I use an
> older Craftsman 3-ton floor jack to jack it up, the front in the center of the crossmember, and the back under the bogie frames, one side at a time.
> It is a chore to lift it at those points even though the 6000# rated jack is 'only' lifting 4000# at those points.
> with me.
> Just what I do.
For emailers, that should read: All six wheels have within a few pounds of 2000# on them.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Isn't there a limitation that when jacking up the front end only lift from the center, or equally from the sides to keep level, so not to pop out the
windshield?
Scott Nutter
1978 Royale Center Kitchen, Patterson 455, switch pitch tranny, 3.21 final drive, Quad bags, tankless water heater, everything Lenzi.
Houston, Texas
Scott,
You can jack up either side enough to allow R&Ring a tire without having to worry about the windshields. You jack up the side just
enough to get the tire off the studs and but the new one on.
Regards,
Rob M.
The Pedantic Mechanic
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Scott Nutter
Sent: Wednesday, December 6, 2017 6:03 PM
Subject: Re: [GMCnet] Jacks and Stands ....
not to pop out the
windshield?
Scott Nutter
Marc,
The 2.5 ton floor jack is OK to use on the front end under the main crossover; while the 2 ton works you are lifting more than you
should with that jack.
Frankly you would be better off getting one of these:
https://www.harborfreight.com/3-ton-low-profile-steel-heavy-duty-floor-jack-with-rapid-pump-61282.html
These jack stands are fine as well:
https://www.harborfreight.com/3-ton-steel-jack-stands-61196.html
However, there is an advantage to the 6 tons stands - they can go higher.
Regards,
Rob M.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Dutch Marc
Sent: Wednesday, December 6, 2017 3:17 PM
Subject: [GMCnet] Jacks and Stands ....
low Profile.
I have used the 2T once when my airbag hose got kinked and didn't want to inflate. I was able to lift the Coach and get the issues
solved.
and heavier 6 TONS?
Grtx Marc
O, hi there again. Great input from all of you guys.
I like the idea of having some ramps at home. ... But ... Since I am a full timer in my Coach I wont have the storage space for it.... Love my GMC so
... Sold my home and took off :)
I checked again and my Jack is a 4 Ton bottle jack, Seems to have 1 stage .... Since I have this I would like to keep using it instead of replacing ot
for a 6 T.
I understand that the 6T stands might be a better option for using them on the back and be able to lift the coach higher. Even these a bigger in size
to store, I think I get me some of those.
About the hook .... Since I got a 2,5 Floor jack, (pretty low profile) I was thinking about using this to get into low spaces when needed and the
using the bottle jack to go further up is needed...
I like the small size of the 2.5T floor jack, I am wondering if I should replace the 2.5T floor jack with a hook instead.
Just try to make sure that I have the right tools needed to get under the coach when needed....
Thanks & Grtx Dutch Marc 8)
