J-24319 tool to remove ball joints
thomas g. warner
1,863
i am replacing the driver side knuckle on my motorhome and no matter what I
tried could not remove the lower ball joint. Finally broke down and ordered
the correct tool from kent Moore tools at a cost of (gulp) $85.43.
when it just arrived noticed that it was in a OTC plastic box with a OTC
number 7503 on it.
Called Fred Keppers at JSC Corp, the place we got the OTC-927 pullers from,
1-800-344-9777. Fred has them for $59. HURT.
so if you need this tool call him.
In fact found out that OTC makes the Kent Moore tools.If there is any you
need call him
Thom:
Several years ago when I replaced my front wheel bearings, as I was
advised, all I had to do was rap a few times with a ball pein hammer, the
knuckle arm eye that the shaft of the ball joint fits into. Alternated with
a few raps on the top of the nut, which was moved flush with the top of the
threaded shaft. As I recall, it popped right out.
Just curious if you tried that method.
Paul Bartz
Sent: Wednesday, August 04, 1999 5:00 PM
Subject: Re: GMC: J-24319 tool to remove ball joints
number 7503 on it.
need call him
paul you name it I tried it. over the last 30+ years I have replaced many
ball joints including the toronado. this devil is tough. I beat it to death
and it never moved. This tool makes it very easy to remove ball joints tie
rod ends etc. Even at $85 it is probably worth it. Stil would have rather
paid $59.
>Thom:
> Paul Bartz
>From: warner [mailto:warner]
>number 7503 on it.
>need call him
