www.harborfreight.com 1-800-423-2567 has a 18pc. seal driver set for $12.99.
Haven't tried this set. Personally I just use a socket thats real close to
the same size or the old seal like Emery states...
Nate '75GB (with a new Caspro engine) Omaha
Date: Thu, 9 Sep 1999 19:25:25 EDT
Subject: Re: GMC: RE: Hubs how to get them off, OTC 927
Walter - I have done much the same thing as Tom over the years. I usually
use the old seal (if its not bent) to lay against the new seal and tap on
the
old seal to start the new one. Be careful about using wood as it can put a
splinter into the bearing. Careful tapping with a small ball peen hammer on
the outer edge of the seal will seat it properly. Light taps and keep
moving
around the seal.
Emery Stora
77 Kingsley
Santa Fe, NM
the
moving
around the seal.
Emery Stora
77 Kingsley
Santa Fe, NM
