Increasing the size of alternator power feed wire?
6cuda61
418
Anyone increase the size of the altermator power feed wire? The stock one on my coach appears pretty small for the job.....
Rich Mondor,
Brockville, ON
77 Hughes 2600
The stock size of #10 provides some protection to the alternator from high currents, especially spikes. If you add a heavier wire, then you will
likely need to install a higher current rated alternator and isolator.
The OEM 3 wire alternator has a remote voltage feed-back circuit which compensates for the voltage drop in the alternator output wire and the
isolator, so worries about those voltage drops are not an issue.
If you have a large battery bank for the house, you may want to look at a DC-DC charger for the house bank. It will limit the maximum charge current
when the batteries are low and charge the house batteries with the proper current/voltage for the battery chemistry, just like a "Smart Charger".
Bruce Hislop
ON Canada
The primary fusible link is a number 16 ga black. DO NOT go to a larger size! GMC designed safety into their electrical systems. The 16 gauge is the weir size that has a fuse rating.
What is a fusible link:
A fusible link acts much like a fuse; only it’s designed to handle a different type of potentially hazardous scenario. These links are actually strands of wire wrapped in a fireproof covering and are thinner (smaller gauge) than the wiring harnesses they’re connected to. They are placed in-line between delicate harnesses and large electrical current sources in your car—between the battery and alternator, for example.
These links must transmit high-current electricity and protect the rest of the electrical system from dangerous spikes that could cause a fire. If there’s a surge, the link actually melts, as its resistance to heat is lower than that of the circuits it’s protecting. This cuts off power while protecting the engine bay from a fire, thanks to its fireproof wrapping.
Unlike a regular fuse they are not instantaneous but heat up before failure.
The NAPA # is BEL 784695 and retails for $4.09 US and you should be able to find it at any good autoparts store in CA.
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
75 GMC Avion (Under Reconstruction)
Michigan
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
P.S, If it is constantly failing Then you must go9 and find the root of your problems. Going bigger just creates more smoke!!!!
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
Michigan
> Bruce Hislop
> ON Canada
Great explanation. It’s an engineered “spring cushion” allowing the alternator to put out a higher Voltage but still maintain correct system
Voltage trim. Any Voltage drop before the horn relay stud junction point is automatically made up by the remote sense to the Voltage regulator. So
increasing the alternator output wire gauge is not a good idea as you are defeating the engineering. Furthermore, if you increase that wire gauge, the
Alternator will get hotter as more Amp draw. This will lower your Voltage as the internal regulator is also “smart” temperature compensating to
match the temp/Voltage curve that the batteries should see. This will falsely lower the output to try to not overheat the batteries.
John Lebetski
Woodstock, IL
The GMC originally came with an 80 amp alternator and the output wire to the isolator was a 10 ga. red wire that went to the isolator before to the rest of the coach. A large number of GMCers have upgraded to the 100 amp alternator. Many have used the AutoZone DL 7157 alternator. I have used that model for years in our first coach. As for upgrading the wire size some have gone to an 8 ga wire. The 10 ga can get warm to the touch under high amp charging mode. The 8 ga wire will handle the higher amp load without issue and will not get warm, the larger wire can carry a higher load than the 10 ga.
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
Michigan
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Thanks for the great explanations guys...I'll leave what's working alone :)
Rich Mondor,
Brockville, ON
77 Hughes 2600
Right I did not restate a stock 80A alternator in my answer.because a larger alternator was not included in the original post. Stock system is
balanced system. Go to a 100A alt and balance is upset. Especially the isolator. You blow open the engine side diode and voltage will go sky high to
house side.
John Lebetski
Woodstock, IL
I'm contemplating a battery to battery charger to the house bank. The
primary purpose is to run a continous oxygen concentrator while traveling,
vs a small portable pulse concentrator. Concentrator pulls 275 watts max,
but is usually only pulling 100 watts.
I believe my coach has a 100 amp alternator, which is prone to crapping out
if the dash AC is run full blast. Would the 80amp be a better option if the
alternator dies again?
Will the batter to battery charger just replace the isolator?
Does anyone have a similar set up; i.e., battery to battery charger,
lithium battery, inverter? I have tentatively decided to use a Battle Born
battery, Victron Orion Tr Smart 30amp charger, and Viction 1200va inverter.
Looking for a bit more education before I commit.
Thanks,
Ken Doyle
'75 Glenbrook
SE Kansas
On Fri, Jul 2, 2021, 12:40 PM John R. Lebetski
> to
> house side.
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
