Thanks, for all the info. I also found a miss wire onthe isolator. Seem to
be working fine now.
On Wed, Sep 11, 2019, 4:52 PM Bruce Hislop via Gmclist <
> Brown wire is the field excitation voltage to get the alternator starting
> to produce power. It has an in-line 10.0 ohm resistance and if you were
> using it for ground on your voltage measurements, that's why it looked
> like the voltage sense line (white) when to ) volts (they both had 12V on
> them!
> The brown wire should have something less than battery voltage with the
> key set to Ign. Wite wire should have battery voltage on it.
> When running, if you have an Isolator (as OEM) then the output of the
> alternator should be 0.7 volts higher than the battery voltage.
> Bruce Hislop
> ON Canada
> 77PB, 455 Dick P. rebuilt, DynamicEFI EBL EFI & ESC.1 ton front end
> My Staff says I never listen to them, or something like that
