I am rerouting some of the wires for my Caddy500 swap. Since the
distributor is in the front of the motor I decided to shorten the ign.
wire. When I pulled the wire out of the loom I found some of the
insulation had melted off the wire. When I pulled the wire the rest of
the way out I found another spot that had gotten hot enough to melt the
insulation. I have no idea when or how this happened. The rest of the
wires in the loom looked to be alright. I spliced a new wire from inside
by the fuse panel.
I have a 76 GB and the bad wire was black with two white strips.
Erv, you might want to have that wire checked to see if it could have
been part of your problem.
The other Jim
by the fuse panel.
The other Jim
