David,
I've had your exact battery configuration for at least 15 years in my
X-Birchaven. It's fine except for a couple problems:
1. Checking/Filling the batteries is very difficult, especially the 12
VDC, positioned as it is laterally 'way back under the
firewall/floorboard. I finally installed a remote battery fill system on
all 3. They're in much better condition now, with little effort from me.
Here's ONE source -- Applied GMC probably has it too:
https://www.amazon.com/Flow-Rite-MP2000-Qwik-Fill-Battery-Kit/dp/B001FCAXZO
Note that you'll need 2 hose kits and one hand pump for complete coverage
-- it IS worth the money.
2. R&R of all of the batteries is difficult -- for me, with radiator side
panels, nearly impossible. The engine battery is especially difficult
being trapped by the house batteries. The easiest way to R&R it is through
the wheel well. I've got the interior 1/2 of my liners permanently
removed, otherwise that will need to be removed for this technique. To
make it feasible for me to R&R that battery, I made a ramp to go between
the Ragusa battery tray and the upper suspension A-arm. Merely a board
with the Ragusa end at an appropriate angle and a piece of aluminum angle
added there to hook over the side of the tray. The battery is pretty
manageable once it's gotten onto that ramp and slid down near the A-arm.
HTH,
On Tue, Jun 30, 2020 at 1:57 PM David Curtiss via Gmclist <
> Hi,
> I am setting up the following on a 3 battery ragusa tray on passenger
> front side.
> (1) 12 volt Engine Battery grounded directly to the engine block.
> (2) 6 volt golf cart batteries for house batteries.
> Where is the ideal location to ground the the (2) 6 volt house batteries?
> There will be no other batteries in the coach.
> Thank you.
> Dave Curtiss
> Mahwah NJ
> 1977 ex-Palm Beach now "Jersey Ltd. Edition"
> Cad 500, Quad Bags
