I am trying to get my '77 Royale back up and running after sitting idle for 4 years.
I have a Howell / Dynamic EFI with spark control purchased from Applied.
I can't find the original documentation and I am having problems with the TPS sticking.
What GM make/model/year would be a good reference for a replacement TPS?
Do I need to calibrate it once replaced?
Currently when I turn the ignition on without starting the engine, WUD displays a voltage 0.4V in the idle position.
Can I just replace the TPS and rotate it to 0.4V in the idle position?
Thanks!
Thanks!
