I guess I'm wondering why you are spending so much time finding exact replacement screws. Is your interior in the rear stripped out so you can see the inside where the screw holes are? If so, glue some SS nuts and fender washer with fiber glass resin to the inside, and find an acceptable SS round head phillips screw as a replacement for the original. Put a little white lube on the threads to resist any corrosion (not likely with SS, but will keep it lubed in case you ever want to take it apart again.) JWID
