Here is the way I did it
http://www.gmcmhphotos.com/photos/data/6460/start_switch_talk.pdf
Gene
> You read Chucks directions and they are spot on. After everything is set
> up correctly loosen to screws and with the engine not running move the
> switch slightly until the back up lights turn on. I do it after dark so I
> can see them on from inside the coach.
> I actually have mine adjusted so if I hold up on the gear shift in reverse
> I have back up lights and if I hold down I have no lights. I did this
> because I have some super bright LED back up lights and do not want to
> blind someone or bother someone in a campground late a night.
> It is a 5 minute job to adjust the switch when everything else in the gear
> shift linkage is set up correctly.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
Alternator Protection Cable
